Good Afternoon,
I ran accross this forum in need of help tuning or diagnosing my Vanguard 16HP V-Twin. I recently purchased a Max IV 6x6 that has this engine in it. I know this isn't a mower, but I figured there are some pretty knowledgable people on this forum with these types of engines.
The engine runs ok, but I feel it needs to run a lot better. Once I get it started the motor revs up and down from the governor trying to adjust itself. I have discontected the governor for the time being, and for adjustment purposes. I'm not sure why a vehicle that has an active throttle would need a governor? I get its purpose on a tractor or snow blower where the throttle isn't always being adjusted and the governor helps adjust, but I don't understand on this. Can I leave the governor un-hooked?
I have pulled the carb and cleaned it. It startes relatively easy, but I don't think its adjusted correctly. When watching the carb while its running it will spit quite a bit of gas out the top (where the air cleaner should be) while in transition from idle to full throttle; is this normal? It also seems to run much better under a little bit of choke. This tells me that I need more fuel; but again under full throttle ,or in transition, it seems to have plenty of fuel (because its spitting it into the air).
Also, there is a needle valve on the side of it that can be adjusted with my fingers; what should this be set at from the factory? Are there any other adjustments I can make other then rejetting if thats the issue?
What are the compression specs for this engine? Cold, I have around 90 psi in each cylinder which seems pretty low. I'm not really looking to rebuild this engine, but I would atleast like to have the carb working correctly.
Thanks in advance for any help, I greatly appreciate it.
-Bryan
-Bryan
