Unknown mower.
Unknown murray
I aquired this mower a couple of years ago. It runs great and other than the tires going flat every week it has served me well.... untill i broke the steering gear and found out i have no way of identifying the mower for replacement parts. The ID plate is missing. Any help would be great.
Scrubcadet10
Moderator
Staff member
I've been tinkering with one just like that except for it's a 6 speed, but the model is 46107x92a
Scrubcadet10
Moderator
Staff member
the chassis might be different due to a different trans being used, but i would suspect the steering to be the same, i can go out and snap some pics of the steering gear etc. on mine if you would like.
Unknown murray
Here is the gear i am looking for. When i pluged in the model number you gave me it came up with a gear that was similar but different enough that gives me pause.
That is the standard Murray steering gear with a slight dental problem ,Viewed from the top
The look different from the underside cause there is the lip to prevent the circlip popping off and the flare to prevent it wandering down off the fan gear .
The bush it runs in will probably be shot & the fan gear pivot hole will be a bit egg shape .
Usually all changed as a set but you can do some welding & filing if you are pushed for cash.
Unknown murray
Lol. Dental problems aside... this one doesent have a lip or flare. It sounds like a later mod to solve a couple problems.
