I replaced the fuel solenoid on my 721D earlier this week, thanks in no small part to the help KennyV provided. After I finished, it started up perfectly several times the same day. Two days ago I went to start it for the first time since that repair. While the engine turned over it did not turn over fast enough to get it started and in a few seconds the rate the engine was turning slowed even more. I put a battery charger on it overnight and tried again yesterday with the same result. Thinking the battery might be bad, i took it to the local auto parts store but it tested fine and had a full charge. Does anyone have any suggestions on what to do next? I do have a volt meter if there are suggestions for further testing...any help will be greatly appreciated?
Geoff
Geoff
