So, I have been maintaining my engine fine for 5 years. This season for whatever reason, I spaced and didn't bother. I was doing some fall cleanup today when I noticed a "burning rubber" smell. It went away and about 30 minutes later, I heard some grinding noise in the engine, then the noise went away. After shutting the engine down, the tractor shook a little. I let the engine cool, checked the oil, which was low. I added some fresh oil and re-started the engine. It sounded "rough" and shutting it sown again gave the tractor a shake.
I was able to bring the tractor in the garage under it's own power. I'm worried that I seized something up and whatever part it is, broke inside the engine.
I'm looking at buying a new engine (bummer, my engine only had 110 hours on it and it's clean all around) or attempting to repair this engine.
I have a little experience with engines, but nothing serious. I can adjust valve clearances, replace gaskets and rebuild carbs, but nothing overly mechanical.
Do you guys think spending $650 on a new engine (I am certain I can take the old one out and put a new one in myself) is worth it, or would I save money by taking the engine to a shop? Is there something quick I can inspect by taking the valve covers off, with the engine still in the tractor?
I want to finish my fall cleanup and smack myself on the head for neglecting something so simple... I really don't need a $650 bill
Thanks for any advice.
BTW: Engine Info on Sticker is: 6BSXS.7242VF 276480 Briggs and Stratton 20 hp V-Twin
