Repairs Troy Bilt TB25ET trimmer/edger
reinkdl1
I am trying to order a new carburetor for my Troy Bilt TB25ET trimmer.
I look up the model it appears that there are five subset model numbers for it.
41ADT2EC063 takes a 753-1195 carb
all the other subsets take a 763-04338 carb
The only other number I can find on the unit is 4MTDS0314RA, 31cc, manufactured in 2004
What am I missing?
mechanic mark
call troybilts 18008285500 number for correct carb. , i located two carbs. ending with 1195 & 04338 also.
The carb itself has the brand and numbers on it..... What's wrong with the old carb ??
(Account Closed)
reinkdl1
Thank you, I will call Troybilt.
The old carb does not have a number. Only China and possibly a brand name like Zama. Carbs are so cheap it doesn't make sense to try and repair or unclog them. I haven't had much luck doing that.
What am I missing?
When I punch your model number into the MTD dealer site the one carb that pops up for your model is the 753-1195. The 753-04338 fits the same series of trimmer as yours but has a slightly different model number. Like 41BDT2EC063 or 41ADT2EC066 the 753-1195 list for $44.00. It is a Zama carb. Part of the model number of the carb will be located behind one of the mounting bolts on the carb. the rest of it will be lazer etched into the side of the carb body in the left upper corner of the cube.
reinkdl1
a
I did call Troybilt and it has been determined that my unit takes the753-1195 carb. The pictures shown also look identical. I asked him if the 1195 and the 04338 are interchangeable and was told no. I will try and clean the one I have and if that doesn't solve the problem I will by a new 753-1195.
Thanks everyone for your help and advice.
