Troy Bilt Bronco Steering Issue
JohnnyGaloshes
I am the purchaser of a used Bronco and the front wheels are misaligned. When one wheel is straight the other is not. Suggestions on where to start or typical part that needs replacing?
THANKS!
MowLife
It’s common for the drag link bar get bent on these models. This is the bar that goes from wheel to wheel attaching to the spindles. It should be straight but normally bows up in the middle if a wheel hits hard. Check this and bend straight if needed.
You may have the two separate drag links that go down to each wheel individually. On those anything from the drags getting bent, to the frame being off kilter, to the steering spindles getting bent, to wear in the front axle pivot can cause the issues that you are having.
