Craftsman Model no. 944.600801 20.5 HP 42" Lawn Tractor (Note the model no. is for a Canadian unit) I have both the owners manual and the illustrated parts list.
After running the tractor for about 30 minutes to cut grass I stopped the mower and put it in neutral.
When I next started it to put it away I could move the lever to forward and reverse but got a grinding noise and no movement either way. I turned it off and pulled the freewheel control out to push it but the rear wheels were locked like when the freewheel control is in to run the mower.
I wondered about fluid in the transmission but could not find a plug to check or top up the transmission fluid. Can someone tell me where that plug is and if you feel it might be a fluid issue or something else?
Thanks
Thanks
