MySmallEngineGuy
- Apr 19, 2013
- 1
- 1
Mod#136O699G022, Ser#2A156C30150. This is a Lawn Chief 16hp briggs, 42" cut. The forward and reverse shift on demand is supposed to go into neutral when you step on the brake while going forward or when stepping on the brake peddle to start engine. This one goes into reverse. I don't see any adjustments for this, the only adj. I see is to center the shift lever to neutral. I'm assuming a worn trans.. Am I right or is there an adj.. Engine#s 42A707, 1238 01, 9601055B
