Kohler courage vtwin 22hp, Finding oil around the base of the engine during use but not above, removed pto and drive belt seal is damp leaks from the frame a drop or two after each use. Pto engaged at next use it squeals a few seconds also (wet belt/clutch?) And resolves.
Was going to replace seal, can't find anything else. Pto was soaked with oil when I bought the mower 4 runtime hours ago.
Please see picture.
Please see picture.
