GregGebhardt
- Mar 15, 2015
- 1
- 2
Have used this Toro Z Master diesel mower for years now and never had any problems. Yesterday while mowing the mower shut down without any warning. Disengaged the blades, put on the brake and started the engine and it started perfectly. The problem is that the second I remove the brake it shuts down again.
I can hold the button to the brake switch to fool the safety system but the second I move the drive bars inward it shuts down again. Something in the safety stop system is triggering that will not allow the motor to run unless brake in engaged and drive arms are pushed outin the parking position.
Any ideas here. I thought is might be a bad seat switch but have tried with both leads removed from the seat safety switch and with both leads connected together with a small piece of wire. Still did the same.
What am I missing, the mower only has 74 hours on it. Please help me as I am going to have to get the dealer to come pick it up on Monday unless they can send someone to diagnose at my house.
HELP ME IF YOU CAN!! Thanks.
