Toro timecutter zero turn - battery won't charge
bstangle
I have a Toro timecutter zero turn (ZTR 1844 TC2X) and the battery won't charge. The battery is charged manually and it will last about 3 cuts on a 1 acre lawn. What is the problem with the battery not charging?
Charge the battery. Install the battery. Start the unit and run at 3/4 throttle. Measure battery voltage. If battery voltage is below 13V you have a problem sme where in you charging system. If the voltage is over 13V you have a bad battery and will need to replace it.
acmclemmons
I have the same problem. batery is new and still won't charge
What engine do you have?
MRCo.
Quick idea. Charge the battery. Find the silver box on the side of the engine, it has three wires o it usually. Pull all he wires off and reattach them. See if that resets the charging system. Do the wire pull AFTER charging the battery.
