I bought a used toro timecutter z420 it had been running great I was mowing when all of a sudden the motor ( B&S intec ) stalled I could not restart
The first thing I did was change the spark plug it started fine it ran for a time then it did the same thing it sputtered an died I checked the plug and it was fouled I took the carb off and checked it out it looked ok and I put it back tried to start the motor and it started up
I mowed for about 15 min and it did the same thing sputtered an died
Thank You
John L.
Thank You
John L.
