I have a Toro model 20057 self-propelled that I bought in 2006.
It has the 6.75 hp Briggs with screw on oil filter.
Is there a way to slightly increase engine speed? There is a governor and no throttle on this model.
No matter what I do or how often I mow, I cannot get a good clean cut on my grass.
I sharpen the blade after each mowing. This mower has been this way since new.
How do I bend the spring loaded governor rod to increase the engine speed?
If you move the rod by hand it increases speed.
I'm hoping a slight RPM increase may improve the quality of cut.
Thanks!
Thanks!
