Toro 20095 briggs 6.75
steveleb
!st problem I have is that I let my son borrow the mower for a couple of weeks. 2nd problem is when I first started it up started fine RPMs
were up. After cutting for a little while around 15 minutes the rpms dropped and the motor died. Started up again no problem made a couple of passes same thing. Finally the mower would start but the idle was very low.
Any help would be appreciated
dougand3
Need the model #...EG: 126M02-0125-F1 Code XXXXXXXX. Probably on a shroud near muffler.
