SteveHartman
- Jul 30, 2023
- 1
- 6
I live in Montana. I Have snow on the ground many times until June. My grass is a weedy style that's 3-4 ft high by the time it gets its first cut. My lawnmower lays the grass over when I run over it, and I have to continually use reverse and go back and forth to catch the top end of the grass to pull it back into the cutters. So, I have an idea. I'd like comments as to whether it will work or not.
Have you noticed how brush hogs are open in front. Sure, some have a chain mesh on the front, but others are open. What I am thinking of doing is cutting the front of my mower to open it up for the blades to hit the grass low without the front of the mower pushing the grass down so far. The front that I cut off, I would take, and tack weld tabs to each end and top. Also run a silicon bead on the cut to seal (gasket) for continued air suction. The tabs would be drilled so that I can bolt the front back on for regular mowing.
Thoughts please! TIA
