Recently bought a Cub - everything that could go wrong with it, has! Spent most of its time in bits rather than cutting grass.
Now trying to find a pulley for the blade spindle assembly (also being replaced) but they are impossible to find. Parts manual says the pulley has the part number 482148 - internet says this has been replaced by part 482646.
I have found a supplier who has part 482744 in stock. The only difference I can see is the material it is made from. The original pulley is made from pressed steel - part 482744 is cast iron.
Anyone know if this would fit ? Or know of an alternative part number - can't be this difficult to find!
