Hello,
While installing the sump pan after replacing camshaft one of the bolts cross threaded the opening not the bolt itself. I need to retap opening.
Motor model is 33R877-0009-G1
This is the part https://shop.briggsandstratton.com/products/briggs-and-stratton-692125-hex-screw
It seems to be a 1/4" width with 20 threads per inch. Am I right? Any advice on this fix?
Thank you in advance!
JIm
JIm
