This can't be right. Briggs & Stratton 595660
PTmowerMech
Greentree is saying this product is 8.40in tall and 7.35in wide. I've never seen one that tall, with the big primer hole.
I don't have the model number, because the QR code doesn't work. It's only got a serial number 12 0410 54 72598.
140cc 550 EX(I think)
PTmowerMech
I'm a dummy. I forgot they still stamped the engine model number on that plate on the side of the carb.
Should be 09P702-0005-F1 based on the serial number you posted.
Model number engraved on the side of the crankcase.
PTmowerMech
No where else does it list this cover as being over 8".
According to IPL that is a non primer model you have and it uses the 595658 cover.
Ever think they maybe measuring the box?
PTmowerMech
Is the primer model. But even those aren't 8"
PT if the engine you have got a primer setup then the serial number is coming with the wrong engine. Maybe Briggs is pulling the wrong engine as the 09P702-0004-F1 is the one with a primer cover but be careful as there are two different primer covers out there.
Actually per the IPL the cover is the 595658 but they are using the 590557 base which includes a primer mounted off to the side of the base air cleaner housing. But doesn't look like the 799584 carb has a connection for a primer.
PTmowerMech
9P 602 0019 F1 is the model #.
The engine model number I found is 9P 602 0019 F1. It's stamped onto the plate beside the carb (facing the front of the mower).
I got the right picture of the air filter cover. Just found it strange that they have the dimensions listed way wrong on the Greentree website. They have the right party number. Other sites I looked at, even amazon, had this same party number, but smaller dimensions.
I've never seen any of these air filter covers as big as Greentree has it listed. So I'm guessing they were measuring the box it came in, and not the actual part.
Looks like the 09P602-0019-F1 is using the 595660 cover. But the serial number that you originally posted is coming back to a different engine than the model you posted. But I have seen the Briggs serial number search come up with some weird results depending on how the serial number is input. All numbers together give one model. Spacing between certain numbers will give another.
