Tecumseh OHH60
Scooterbum
Anybody familiar with the timing gear on this model?
I was told it's a press fit on the crank and am trying to find out if it at least has some timing marks to put it back in place. Thanks
reddragon
you need to give alot more background than that ..
Scooterbum
I was told by an unreliable source that it was a press fit with no key or marks.
Was just hoping to find someone that has had one apart.
reddragon
someone here knows....they just havent seen your thread
reddragon
can you take pictures?...pretty please:biggrin:
jeff
It has been a while since I worked on one of these, but I do not recall the gear being "pressed" on. As I recall, the gear is slid on and there is a non removable key on the crank. The gear does have timing marks.
