I sent the following after contacting the U.S. Consumer Product Safety Commission. I was told that all recalls were handled by email and was given Kyle Kubista's email address. His response was to the point and said my engines did not fall into the recall. My question to the forum is, Do any of you have this problem? While reading online about my problem I see where the Earthquake auger is one of the pieces of equipment that commonly has gas leaks and it might just be coincidence , but the same engine on my Troy-Bilt has the same problem. If anyone has any experience with these engines and this problem please give me a clue on what the possible cause is. It is not the fuel lines because I replaced those. Thanks for reading this.
Dear Mr. Kubista,
I have two pieces of power equipment and each have the same Tecumseh engine model TC11 and they both have the same defect which is gas flows steadily from some point near the carburetor. They both run, but I think the gas leak creates an unsafe situation and I have discontinued use of these pieces of equipment. I see online that there is a recall of this particular engine and I would like to participate in that recall and have my equipment repaired to a safe condition. The equipment I am referring to is as listed.
Eartquake power auger and the following numbers were found on it TC300 3204H ( B ) 2269CA The auger is manufactured by Ardisam, model #8900, serial #186616
Troy-Bilt garden tiller, The only number found on it besides the TC11 are TC300 3196F ( B ) 9237G
I contacted the The U.S. Consumer Product Safety Commission. I was told a recall does not expire and they gave me your contact information to have the problems I have taken care of. The information concerning this recall is on their website
Originally issued April 4, 2006
Revised November 27, 2009
Release #06-130
Dear Mr. Kubista,
Release #06-130
