Tecumseh Enduro engine, Float needle
Mac 624
I own an german made MTD Mower with a Tecumseh Enduro engine.
The carb is missing the seat of the float needle
bowl.jpg picture by D624S - Photobucket
itエs the one right above, blue signed. Does someone have a pic of it? Is it made from metal, plastic or gum?
Thanks in advance
Bernhard
It is rubber and should be included with a replacement needle valve.
Mac 624
Thanks, thatエs the answer I needed. Noone here was able to tell me, if it comes with the kit. Maybe I try to make one by my own, cause they ask appr. 70 USD for float needle and seat. Float and needl on my engine are ok, so no need to replace them.
Do you habe any measurements about it?
I looks like a rubber disc with a hole in the middle and the edge where the needle sits is beveled.
