Hi,
I am having trouble with idling speed of the engine. In essence the the engine will not idle, it is either on full revs or off; the idle control lever on the carb is not moving when I adjust the throttle. The pin on the engine case that the idle control spring is attached to seems loose.
Any ideas anyone??
Regards,
Darin.
Any ideas anyone??
Regards,
Darin.
