Tecumseh 10 hp HM100 Carb rebuild problems
TheBishop
I have a Colman Powermate generator that is 30 years old and up to six weeks ago was running great. We used it for 2 days during a power outage. I have kept it clean and start it every few months and let it run for 15 minutes to freshen the gas..
Today due to another storm coming into Florida I started it this morning it started on the second pull like it always has but it ran for about three minutes and quit. It's got good fire. I took the carb off and took it apart and blew out all the holes and everything looked good. I put it back on the Tecumseh 10hp HM100 engine but now it leaks fuel out the air cleaner. I took it apart again and checked it out and reinstall it again and it still leaks out the air cleaner. I did not install a carb kit since I rebuilt the carb three years ago to get a new rubber seal ring for the bowl under.
No leaks from any where else just the air cleaner.
The needle valve was clean and sharp and the float floated fine.
I looking to just replace the carb now. What do you all think about fuel leaking out the air filter?
Thanks
It will be the seal under the float needle.
Modern fuels soften the rubber.
If you get a few years out of one, you are doing well.
TheBishop
I replaced the Carb and all is well again
