TB bronco 13YX78KS011 bent rear axle
macsda1
Hello out there, I have a bent right rear axle/hub on my 2013 troy-bilt Bronco mower. Besides the wobble can I still get years of use as is? Is this something a diy person could replace? I've replaced axles on cars. And does anyone have an idea where to get axle and about how much they are? Any thoughts would be appreciated. Thanks in advance
How did you bend the axle on your 2013 mower. MTD doesn't show a parts breakdown of your tranny, so you may be out of luck for now as far as parts.
Your transmission has a part number of 918-04566. This website has a breakdown of the internal parts
OEM Parts
