why do the pinion gears keep wearing out on my honda self prop
R rpraborn Forum Newbie Joined Jun 24, 2018 Threads 3 Messages 5 Jun 25, 2018 / stripped pinion gears #1 why do the pinion gears keep wearing out on my honda self prop
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 55 Messages 14,846 Jun 25, 2018 / stripped pinion gears #2 Have you checked the pinion gear bearing and the axle bearings. If any of them are worn, you will probably have found your cause.
R rpraborn Forum Newbie Joined Jun 24, 2018 Threads 3 Messages 5 Jun 26, 2018 / stripped pinion gears #3 Rivets said: Have you checked the pinion gear bearing and the axle bearings. If any of them are worn, you will probably have found your cause. Click to expand... thanks for your response, I am going to replace the wheels altogether,and pinion gears.. kill 2 birds with one rock.
