string trimmer CC4025
richinohio
When using, it dies under full throttle every few seconds. Took carb apart, cleaned, blew out orifices and now it will not run at all. The primer bulb is very very slow returning after having been pushed in to prime. What did I do wrong?
timtractor
Try replacing the fuel filter in the tank. I had one the the filter pluged or colasped and suffocated the fuel flow.
