Hey All
Have a strange problem with my Bahia ride on mower the engine is the Briggs diamond ic 13.5hp
27M707 - 1187 - E1 Code:980413ZB
Image here https://goo.gl/photos/aFMVtm5a96UF69L66
I have swapped in a complete new loom most of it was self explanatory to fit as it was mainly safety switch plugs etc.
now if I put the key in and turn to 3rd stage start, the engine cranks as it should but even it there is no one on the seat.
if I push either forward or back pedals it wont start, if I leave the handbrake off it wont crank which is as it should be but the seat switch makes no difference.
the loom is new also replaced the seat switch with a new one. got my fluke meter on it and it tests fine.
also strange is that if I turn they key back from last stage it tries to start???.
its had the following new parts all genuine fro briggs and stratton:
new key ignition switch
new solenoid
new fuse holder
new looms
new starter motor
new fly wheel and key
valves checked and set perfectly.
I also noticed there was no wire from the ignition coil as a stop the spade was half missing so I've soldered a wire on but unsure of its location.
any help would be greatly appreciated
kevin
new solenoid
new fuse holder
new looms
new starter motor
kevin
