Lawnranger - thanks for your review. I just sold my Wood Boss and after reading your comments I'm leaning back to the MS 250. I noticed comparing the specs that the MS 250 is 10.1 lbs vs 10.8 lbs for the MS 250 C-BE ... so those extra features add both design complexity and weight.
Without a priming bulb, my Wood Boss would take 6-7 pulls to start cold. How many pulls does your MS 250 take?
Thanks again for your input.
Two to three pulls on full choke usually makes the saw "burp" (attempt to start) and then I move the multi-function lever up one position to fast idle which opens the choke and another one to two pulls usually gets it running. Since you already owned a Stihl saw, you know that if you pull the starter cord just one more time on full choke after the saw burps, it will flood. If I had a nickel for every flooded Stihl saw that came into my shop, I'd be a richer man.
I was concerned about the lack of a purge bulb on the MS 250 but it hasn't hindered starting in the least. I prefer a lighter chainsaw and when I sold my McCulloch 3214 I replaced it with the MS 250. The 250 is heavier by a significant amount compared to the 3214 but still very easy for me to use. In comparing the MS 250 Vs. MS 250 C-BE, the .7 pound difference and lower cost swung me to the MS 250.
I talked to several professional tree climbers and they both use an MS 180 for the weight advantage. I know the MS 180 is an occasional use saw but the people who do this every day will use it like a pro saw. The cost is low enough to when it wears out you just figure the price of a new saw into the next job. Knowing that some professional tree climbers us the lowly MS 180, I figured a 250 would serve my needs well and it has so far.
My brother-in-law had a Wood Boss and literally wore it out from so much use but he got a smokin' deal on a Jonsered that he is very happy with.
When you buy your new Stihl, make sure to get a 6-pack of Stihl Ultra 2 stroke oil and by doing this you will double your warranty period automatically. A few more pieces of advice are to use 89 octane fuel or higher as recommended in the owner's manual. I use Marine Formula Sta-Bil in my fuel to help keep the fuel system clean and the fuel in good condition. If my fuel mix is more than three months old I replace it with new mix as the need arises. I do use the older mix in my trimmer and have had no problems. If your saw will sit unused for longer than a month, buy a can of Stihl Moto-Mix which is a quart of 92 octane, premixed 50:1, ethanol-free fuel using Stihl Ultra oil. If I'm going to store my saw I will drain out the pump gas mix and pour in about 1/3 tank of Moto-Mix and run the saw for a minute to circulate the new fuel. By doing this you will postpone the negative effects of ethanol on the rubber components of the fuel system. Or if you only use your saw minimally you can use Moto-Mix exclusively. Moto-Mix retails for $7.99 a quart so for me it is cost-prohibitive at over $32.00 per gallon after tax.
I hope all this info helps and if you have any other questions just ask. Now go out and get your new saw so you don't prolong the agony.
