I have a newer generation FS80 that refuses to start. Since replacing the spark plug and splashing gas into the carb didn't yield even a temporary fire and the spark seemed week, I replaced the coil module. Still no joy. In addition to replacing the module, I've replaced the spark plug (again); torn the carb apart, cleaned and reassembled it; removed and cleaned the exhaust/muffler; verified the on/off switch is working.
While the carb and exhaust were off, I checked out the piston/rings, all that looks great.
(Background, it quit during my last trimming of the season last fall. I was using it, turned it off and it wouldn't re-start at that time. Figuring it was the spark plug, I set it aside until now.
I'm really stumped that I can't even get it to fire knowing there is spark and splash of fuel in the chamber. I went as far as to hit it with a couple shots of starting fluid.
I'd appreciate any words of wisdom you all could share.
Thanks!
Thanks!
