Starter Problem.
Don't do videos, can you post the problem?
LaWn GuY
Whats wrong with the video^^^^^^^^^^^^^^^^^
I didn't say anything was wrong with videos, it's probably great for the younger guys. I said I don't do videos. sorry for the misunderstanding.
Carscw
Holly F-ing crap.
Bet that starter has a good burnt smell to it now.
Adjust the valves
LaWn GuY
I've adjusted the valves at least 10 times and still nothing when I first got the starter it worked fine after about each use it seemed like it loss power. I seen a little smoke come from the starter.
Carscw
Give the battery a jump with same cables from the car
Fish
It spun good at the start. Take the plug out and crank it, film that. Then screw the plug in 1/3 of the way and crank.
BlazNT
The starter gear should drop down after you try to start it. I'm betting bad starter.
Fish
Yeah, reading the posts, I am sure that the starter is probably toast, just don't know what caused it yet.
