I took the starter assembly off to find the starter pawl had popped out and was broken. I am replacing the plastic pawl and spring. I am not sure how to put the spring on. I can find no diagrams. Also, once I figure out the spring install, which direction shout the pawl be in the cup ? Vertical or at a 90 degree angle ? Pictures are always best for me. This is in a Echo HCR 1500. Thanks for any help.
