Starter bolt stripped.
LaWn GuY
The bolts go In but wont tighten could I jut put a bigger bolt on? stripped_bolt.jpg
Carscw
I would try a new bolt
LaWn GuY
I did try a new bolt same thing.
LaWn GuY
When I buy a heli-coil kit do I need to take the bolt with me?
motoman
Looks like steel bolt into aluminum and has stripped aluminum into the bolt threads. Helicoil is a good fix . Seems you will need oversize drilling and mandatory perpindicular (90 degree) drilling. If you (or a friend) are good with tools you might be able to tap to the next size bolt directly into the aluminum. The stripping may be the relsult of over tightening. Use a torque wrench and the proper value for the unlubricated ( or lubricated ) bolt. See chart this forum.
Fish
Yes, take the old bolt with you, the helicoil kit will have the tap and instructions you need, don't be drilling at it first.
LaWn GuY
Fish
OOOOh, quite nasty.... May be too far gone....
