Hi, I have a spin steer 15hp made by John Deere. I had to just replace the steering column and fan gear now it pulls to the left. No problem the manual told me to adjust a nut on the transmission easy to get to thru the frame on the back of the tractor. When I did this it took the tracking problem away but now when it is sitting idle it will spin in a circle slowly. The manual says this is creeping and to adjust the same nut I did for tracking but it wants me to turn it in the opposite direction. So I can have it pulling to the left or when I stop, have it spinning in a circle slowly. Anybody have suggestions?
