springs missing at carb
ddunn
got a used snapper self propelled with a briggs and Stratton 12j802 with no springs at the carb does anyone know how many and how they hookup
Catherine
LawnWorld Support
Staff member
:welcome:
Welcome to the forum!
I'm going to move this thread over to our Briggs & Stratton engine section.
Yes you have an older L head engine. Give us the Type numbers also.. Do you have the primer bulb or the choke type ??
Let us know Mon Ami ~!~!
Boobala
YOUR FIRST post ( CONFUSED ) is about the same as this post, ... DOUBLE-POSTING does NOT get you a faster reply, and only adds to confuse those trying to help as it gets chaotic bouncing between multiple posts from the same person, on the very same issue, it's fine to post more than once, but about different issues, or include your other issues in one post, also, pics, (if possible) would be helpful .. :thumbsup:
Ddunn you have 1 spring for the gov and it hooks to the gov rod and goes to the front of the engine on a plate that the carb is screwed to.
There are a few vids on you tube ........ I have a few vids, but I don't remember if I have one on that spring.......
ddunn
ok thanks I'll check out you tube
