Thanks to the pros for any help you can give me. I have a 1997 Lazer with a 52 inch deck and one of the spindles is really sloppy so I wanted to replace it. I see it bolts from the bottom and the first bolt I tried to remove twisted off. Are these reverse threads by chance? If I wind up twisting all the heads off will that spindle lift right off the deck? Thanks, I need to do it myself and save the money. Any opinions of the spindles on ebay for $60?
