Spare parts croquis for Poulan 22hp 48
Freedom
Hello I have a Poulan pro
PB 22VA 48
I would like to see a sparte parts croquis to identify the ID code for each part . And then buy it in Amazon
for example I do not find the air filter code and the oil filter code.
any help?
thanks!
F
The air filter and oil filter would be considered engine parts, So you will need to get the engine model number information off of the valve cover opposite the one with the fuel pump and then look that up to get the part numbers for the engine or post it here and we can get you those part numbers.
Freedom
Thanks for the answer:
My serial number is
(INTEK by Briggs Stratton)
150116YG 88825
is that ok?
With this serial number could I find the air filter ID and other spare parts?
Thanks!
F
Boobala
MORE like this , see EXAMPLE ......
GET INFO.JPG ...... click to enlarge
Freedom
Hello
back here, I have a Poulan Pro 22hp with Briggs Straton
my model number is:
Mode, 44R677
Type, 0032 G1
code, 15 01 16 YG
Where could I get a Spare parts list and an illustrated parts diagram of the motor?
thanks
R
