Hi Dave from Wisconsin - looking to buy a Husqvarna rider model YTH22V46. My old mower died and after much research seems to be a good mower. Of course, I am sure they may be some bad things about any mower you buy - was wondering if someone can either give me Yay or Nay on this unit? Any know problems I may run into and if so any way to avoid? I see the spindles must break under the unit if you hit something - is this common? Is it easy to fix & is it expensive - can I do it my self? My main question is what roll does the spindle play - is the spindle that breaks what the belts go around or is this the spindle that blades are attached too. I am not a very handy guy so if I can avoid things I will definetly try and avoid hitting anything in my yard. Thanks think I will love this site Dave
