BustedKnuckles
- Sep 26, 2012
- 16
- 119
Hey folks! I recently bought this tiller from the original owner and it's been sitting unused for several years. What I've found so far:
THE BAD
Oil level is low and black (like everything else I buy it seems)
Tine drive belt has chunks missing
Left tire leaks down
Tine engagement cable is missing some handlebar parts
Compression seems to be low by my hand to brain compression gauge
THE GOOD
Its all there except for the tine cable pieces
Tank is clean (surprise!)
Carb is pretty clean
Axle boots are good
Tine seals seem to be OK and have some slight seepage
Both the drive and tine cables move freely in the housings (after some light oiling)
Engine has good spark
I've already started the carb work and should be putting everything back together tonight along with some fresh oil. I doubt I'll have time for startup but we'll see. Belt replacement will happen after I get it running.
THE BAD
THE GOOD
Axle boots are good
