Have a snapper self propelled mower with a B&S engine with a weird problem. It starts fine, will mow for 15-30 minutes the loose power and die. I can prime it and start it back up then it starts acting up all over again about 5 minutes later. Done the usual, changed plug, airfilter, gas, oil, etc....
Even when it start to die if I am quick enough I can reach down and prime it while it dieing and it goes for a few more minutes. On thing I notice yesterday when mowing is I can take the airfilter completely off and for the first time it ran the entire time I needed to mow the grass with out dieing on me. Of course I know running the mower with out a air filter is not the best solution. Any suggestion. Also as a side not sometimes when I power down the mower it will stay on and sputter for a short while befor it shuts of. Had the carb rebuilt last season also.
