Simpson pressure washer sprung a leak.
Scottcc
I know it’sa mower forum, but I do believe I can find the best answer from you guys. The hose connector to the pressure unit is leaking and causes low pressure. This is a picture of the hose connector which is obviously peened. I think both connectors should be replace but what is your opinion.
Looks like a quick disconnect coupler. Have you checked to see if there is a missing O-ring? Giving us the model number would make it a whole lot easier to help you out.
Scottcc
No O ring that I can find. Model # for the triple A is DW3635. Thanks.
Scottcc
