Simplicity Regent rollers...how to remove...........
halm
Am totally frustrated by the Simplicity Regent roller system. Blades high, rollers still on ground so cannot mow where there are roots, rocks, etc. Have removed and built a bracket to support left side of deck but am limited to that height. Anybody have a better idea ?
mechanic mark
First don't remove rollers, they have a purpose. I would not be mowing over rocks & roots, use a weed eater, or place deck at highest setting & mow. If you try to mow with lower setting you'll be in need of new blades soon.
