Simplicity Brush Mower with 13.4 hp intek Briggs & Stratton
skleppin
  • / Simplicity Brush Mower with 13.4 hp intek Briggs & Stratton
Howdy,
I have an older Simplicity brush mower I use on my tree farm. When I engage the mower blade and cut, it dies after a few minutes. Heavy brush makes it worse. Eventually it will even stall after the blade is disengaged. Increasing the throttle makes it worse. Air filter cleaned. Coil replaced, new gas. In talking with the guy that does my repairs, he feels the carburetor is the last option. Any other ideas? Thanks, Steve.
I personally would have started with the carb. Post the engines model and type and code numbers so we can see exactly which engine you have. Briggs built a variety of 13.5 hp engines.
skleppin
Thanks for the reply, I appreciate it. 21B977 0120 E1 031120ZA. For the record, I am no mechanic. I just hoping to get to all possibilities of the problem so I don't get it back from repair and it does 10 minutes later. Steve
mechanic mark
Replacing a carb would be a last option, but cleaning and rebuilding should be high on things to do. I would have done it before replacing a coil. One other thing on those engines is a blown head gasket, which will show up as rougher running engine as it warms up.
mechanic mark
https://www.google.com/search?q=B&S...ome..69i57.26811j0j4&sourceid=chrome&ie=UTF-8 WALBRO carb. overhaul kit
https://www.google.com/search?q=b&S....69i57j0l5.18144j0j4&sourceid=chrome&ie=UTF-8 NIKKI carb. overhaul kit
skleppin
