Nwatson99
- Jul 29, 2013
- 18
- 531
Gents what lift rack do you use for maintenance work under your mowing decks?
I currently have the MoJack 300lb lift cap I use and it seems to work just fine and not over weighted according to my calculations on the axis pivot point, but with the new mower on order and the more complex MOD deck it appears I will have to go under the deck for more extensive cleaning and inspection.
This evening I was reading good reviews and liked the structural design with the weight and lifting mechanism, so I decided to get the MoJack PRO Mower Lift.
Yes it is some overkill, but I cannot move as fast as I use to and feel with double the weight capacity with holding, using the strap for lifting vs a screw rod, plus the geared lifting system and locking device, it is the best for safety while under a commercial machine and mowing deck.
I should have asked this before I ordered, but good thing I have until Monday to find a better solution and cancel the order if need be.
