scag tigercat won't crank
handleBar
parked the mower after using it. Went out a week later to cut grass, and it wont start.Called scag tech. they said that the relay was usually the problem. Bought a relay. All switches read good, new battery, still it wont turn over. I really don't want to purchase a ignition module. Can anyone help?
mechanic mark
Request Rejected click on your serial number & see electrical schematic, check engine oil level, check fuses, relays, wiring by hand, seat switch connection & all ground wires & straps.
