:confused2: The 27 hp kawasaki has 659 hours, and is an 2002 with reasonable care, garaged. The engine had been running well, but started cutting out after just seconds or minutes after starting. It has good power while running, and seems to need some choke to start even when warm. I disable the safety switches, and installed a new fuel filter, and fuel pump, tightened the fuel connections, and checked the fuses. Just right oil level, and gasoline in the tank. Any ideas? Is it that electronic ignition? Help would be appreciated. . .
