Ryobi RM480e ride on won't move
Pierre
HI I just read some comments from other users who have had the saame problem
I bought my RE480e Jan 2021 and untill this week it was fine.
Now I cannot move froward or backward.
I have still full batteries and i on a hunch disconnected them to put a load tester on them.
All held 8 volt under load. I then reconnected everything to see if the variable resister at the accelerator pedal had voltage, it has a variable output when moving the pedal.
Also checked the brake switch which works fine.
I suspect the drive motor controller is on the blink.
If i sit on the seat, switch on and push the go pedal, i get a slight movement which immediately stops. Nothing in reverse.
Any thought of how to check the in and outputs there?
It is still under warranty but i am quite a distance from any service agent.
