- Nov 29, 2014
- Threads
- 64
- 24,718
Pull the engine cover and the flywheel nut and do a quick check of the key.
The 2 halves of the hole should form a perfect square if not pull the flywheel.
As we have stated many times we only have what you tell us & show us to go on.
Usually a partially sheared key will advance the engine which exhibits different symptoms to being rich.
However a retarded ignition will cause some black smoke as the fuel will not have time to burn fully.
At this point in time looks like we will have to start looking at outside possibilities.
