Hammermechanicman
- Jan 10, 2020
- Threads
- 56
- 3,543
Another big problem is that people don't replace the flat o-rings on the intake manifold and they have air leaks. The OEM get hard and compressed and the cheap AM swell from the ethanol. I stock a dozen of them as i change a lot of them.
Biggest problem Next to the jet o-rings on the 2 bbl carbs is the tiny passageways under the w shaped plate. Ultrasonic cleaner usually gets them clean but the carb cleaner spray guy usually miss them.
