I bought one of the RMA 460 electric mowers a few weeks ago. I love the mower for my small yard except for one thing. And.. That one thing would keep me from buying it again or recommending it to anyone.
There are plastic pieces on the front and back of the mower deck. The front pieces are there to direct the air flow into the deck and to hold the front wheels on. The back is for the grass catcher or plug that turns it into a mulcher. In both the front and back there is a gap between the deck and the plastic pieces on the underside of the deck allows gras to get into the area between the plastic pieces and the deck every time you mow. If it is wet at all, it ends up molding and stinking. The front area also drains green slimy water out for a few days till it dries. I took care of the back by caulking the gaps between the deck and plastic pieces. (We'll see how long it lasts) The front is not so easy. To clean the area out you have to remove the front wheels, take 8 screws out, take the plastic pieces off and clean out the mower deck and plastic pieces. Not really acceptable, its messy and it takes a while. Looking a pictures of stihl mowers, it looks like these plastic pieces are a fairly new add on to the design. Pictures of older mowers have a smooth underside of the deck.
Has anyone else had this problem?? I'm thinking of either drilling the front plastic pieces full of holes so I can at least spray water into the area and kind of keep it cleaned out or just drilling a few small holes and filling the entire void with spray can foam.
