OK.
I stand the mowers up on their bums after dropping the deck, draining the tank & removing the battery.
It makes things a lot easier when you can see everything in front of your face without geting a face full of dead grass.
Set the parking brake and slip the belt off the drive pulley.
you can leave it between the drive & Deck pulleys for the time being.
This will give you enpugh slack to slip the belt off the tranny.
I generally slip the belt between two fan blades and rotate the input pulley the remove the belt.
You can now release the brake to take spring pressure off the clutch pulleys as you will have to remove them to get the belt past the belt keeper.
There will now be enough slack to remove the belt from the engine pulley completely.
Check the two idler pulleys for wear, particularly for thinning of the flange and of course the bearings for smooth & quiet rotation.
On some Troy builts you will also have to remove the gear from the bottom of the steering stem and push it up if the belt runs either side of it.
These modls typically hav a snap ring holding the gear on.
While it is out lubricate the bush.
